Hi
I am planning on increasing my memory on my PCG-K115Z.
The memory required is (same as A-series I believe):
DDR SO-DIMM PC2700 512MB CL2,5 Non-parity, 2.5V, 64M x 64, 6ns, 200p
The best price I have found is £63.00 each, and I will need 2;
@( http://www.komplett.co.uk/k/ki.asp?sku=122445&cks=PRL )
I did look up the sony product (VGP-MM512G ) which sells at £150.00ish!!!
Does anyone know where there may be a better deal than that at Komplett?
cheers
GBS
Crucial do good deals (www.crucial.com/uk/)
Thanks again Kee-Lo
