Just one question, I would like to upgrade my memory to 8 GB, 4 GB is kinda low for me. My laptop memory runs at 1333 MHZ, just wondering is there a particular module for vpcz217fc or any memory runs at 1333MHZ will do . Thanks for you help.
The memory is soldered on the motherboard.so never mind, you can't upgrade it.
Hi adiphia,
Unfortunately you are right. The VPCZ2 models do support 8GB but this must be preinstalled at the factory and cannot be upgraded later.
