Hi all, i have the Sony Vaio K215B and just wondered if it was possible to upgrade the video card in it as it comes with a pathetic 64mb integrated.
Thanks in advance
Thanks in advance
Thanks a lot, I will try the drivers
Check your BIOS settings as well just in case, some of Sonys laptops actually borrow system RAM, and you can change how much they borrow. I forget which ones do and don't have this so you would have to look. Otherwise Woodys suggestions is as good as it gets I'm afraid.
The Radeon 314 IGP or something similar.
