I can't download updates to the media center guide. I get "Critical Process Failure Code 3" & "File validation error - mismatched guide package. Code: 22"
I'm using XP MCE on a VGC-VA1 desktop.
Hope someone can give a fix which a non-technical user can implement.
tks/rgds,
a12th99
Hi a12th99
as know one appears to know of a solution, you could see if the following links offer any clues to solving your problem.
MS KB910905
MCE not working (Critical Process Failure?)
Hi a12th99
as know one appears to know of a solution, you could see if the following links offer any clues to solving your problem.![]()
MS KB910905
