Unstable touchpad when charging?
pringe83
Visitor
My touchpad on the N31Z works fine when using battery power but is erratic and unstable when the AC power is connected. I have read that the touchpad uses a tiny amount of electricity to detect body movement over it and am wondering if there is some sort of overload or malfunction taking place? I have searched for driver updates and no luck.
Any advice much appreciated,
Thanks.
5 REPLIES 5
pringe83
Visitor
...just to add that I have tried removing the battery and running off AC power. The problem disappears - so it is only when charging the battery that I have this problem.
Any advice or people experiencing a similar problem?
pringe83
Visitor
[BUMP] Really anxious to hear any comments!!
profile.country.GB.title
Thalamus.
Champion
Hi pringe83
Has your touchpad always behaved like this when using AC power.?
pringe83
Visitor
Hi Thalamus, yes I think it has always behaved strangely on occasions, but after reading on this forum about VAIO's support and the length of time without laptop whilst it's sent away for repair I decided to put up with it! It's only recently as I have begun to use it more and more without an external mouse that I've realised exactly when it malfunctions.
Any suggestions? Have you heard of this before?
Thalamus.
Champion
Hi pringe83,
No I don't recall anything being mentioned before, it sounds hardware related to me.. :slight_frown:
But try this..
Press the windows key+R to open the Run box type devmgmt.msc and press OK
Click Continue on the User Account Control window.
Is there a pointing device or PS2 mouse listed..?
If you do not have a pointing device listed, then right click once on PS2 mouse and select Update Driver Software.
Select Browse my computer for driver software, then Let me pick from a list of device drivers on my computer
If 'Alps Pointing-device' (possibly Alps Pointing-device for Vaio) appears in the new window, select it and click next.. (if the 'Alps Pointing-device' does not appear in the list remove the tick from 'Show Compatible Hardware' and select Alps Electric from the Manufacturer column then 'Alps Pointing-device' (possibly Alps Pointing-device for Vaio) from the model column and then click next.
Follow the on screen instructions to finish.. :slight_smile:
