Hi all,
I have a hard time here with my RX-306 which is mounted for dual boot: XP and mandrake (as of last week mandriva).
When I boot under XP I get a blue screen stating: UNMOUNTABLE_BOOT_VOLUME
Has anyone got experience with that error?
Under mandrake it is fixing errors it seems and I got so far as to log in as root again on the command line.
Waiting for some feedback now before proceeding.
Tnx
Ugh. That's the last thing I saw before my computer went to the Vaio Hospital
Damn
Yeah. In my case the part of the HD containting the Metadata or something equally important had failed, but it's more likely that XP has become unrecoverably corrupted and requires a reinstallation. There may well be a way around it if you look around the net for a solution, but with the recovery process being what it is, there isn't much room for improvisation.
I know, the advanced user is disabled by Sony's choice.
Hi guys,
Tnx for the MS-link.
I will keep you posted on this.
Later / Danny
Good luck man
