Hi everyone --
Have a TX1XP and love it except for one (pretty significant) thing. Whenever I connect to a wireless network, the quality of my connection is only intermittent. My computer keeps disconnecting for v. short periods and then reconnecting. Has anyone else encountered this problem or does anyone have a suggested solution?
Thanks in advance,
Marcus
Hi Marcus and welcome to ClubVaio.
Have you tried increasing the WiFi performance to Maximum?
Start>Right-click on My Computer>Properties>Device Manager
Expand Network Devices and double click on your wireless adapter, Under Power Options choose Maximum Performance,
Hi Blencogo --
Thanks for the last suggestion. It appears to have worked a treat.
Cheers,
Marcus:smileygrin:
