The advertising blurb says 7 hours battery life. I'm lucky to get half that.
Be warned!
The printed battery life is often exagerated
VERY much so in this case!
So I am the lucky one who really gets more than 5 hours... of course without using the optical drive. Never needed 7 hours, so I can't tell you the maximum.
I guess I get about 4 1/2. Certainly not 7
carthorian is absolutely correct. having owned a few vaio subnotebooks over the years (srx77 series, even the japanese u70 palmtop pc) the power settings are indeed, powerful. i get abt 6:45 using the adaptive cpu setting w/ the i-link, cd and modem disabled! i watched 2 movies via the hard drive last night and still had 4:30 battery power left... i used a 4 setting for my lcd brightness. the white led powering the display really, really saves lots of battery.
also, i'm sure defragging your hd (i use diskeeper and highly recommend it--better than norton's speeddisk which i used to use for years) helps too.
carthorian - Thanks for the info. i'll give it a try.
Hi Everybody,
I bought mine one month ago and gets about 6 hours without optical drive and less than 3 using it.
