Hi everyone .i just bougth a lcd tv and i want to switch my vaio to it .the problem is i havent got it as a option any more.i have a tv out and i ve used it before so must be after i pre-instal my vaio a mount ago i ve done something.ive must have deleted some drivers .,or something ive got no idea. If someone can help. THANK YOU.the model is PCG-FX802P(XP PROFSSIONAL):smileysad:
Could be that the re-install loaded generic drivers for your graphics card. You need to find and install the correct drivers but these are not available at Vaio Link for your particular model. Try searching your original recovery cds.
