always liked the look of the mac interface but could never aford the price tag ..so i bought the vaio ..instead which has been a great .i download this http://osx.portraitofakite.com/ which turns you xp into a mac interface been runing for 3 weeks now and runs great also it free .tell me what you think
Wow. I'm so glad I had a look in and saw that! Absolutely fantastic, I love it to pieces, especially in combination with some of the non-bundled software he recommends.
Brilliant .:D
Thanks for the link irishpureblood,
I have to agree, very impressive indeed
Word of warning. If you share your log in as I do it won't install properly for your login partner. Also when it system restores it leaves many Mac icons behind. AdAwares ad watch resident protection is not compatable and replicates and switches off if you try to commit it to the task bar You can just leave it's dialogue box open on the desktop. Apart from that it's very cool.
Thanks for the info Tony.
I have mutliple user accounts and would have had no end of grief if they were unable to log on....
Sounds interesting, worth investigating
to irishpureblood
If you really love mac os why not buy a proper mac laptop,, there are a lot of mac laptops there that are much cheaper than sony viao. I only say this Coz to me you sound like that you only bought your vaio coz you couldnt afford an apple laptop, which is sounds like to me again that your sony vaio is just a second option.(which is not good to read if you are in a vaio forum)
As Apple are now using the simular Intel chipsets that Vaio's have been using for years are they not following Sony? Don't get me wrong I was trained on Mac's for graphic design but went PC for the CAD applications which render graphics anyway and give you 80% more software choice. Could do without all the BS security update measures however. If the screen is as good as a Sony I might go for a duel boot MAC next time. Are they?
to irishpureblood
