Just got me a 40GB Vaio - very shiny. I've run the firmware update (version 3.0.0.C171F), got the latest version of sonicstage (version 2.3.00.11020) and the Vaio transfer wizard (version 1.2.00) but i still can't get sonicstage or the transfer wizard to allow native mp3 support.
Is there somethign REALLY obvious I'm missing? If so, could you tell me in a way that makes me look less stupid?
Cheers in advance
-JBM
You cannot convert to MP3 using SonicStage, you can only transfer files that are already in MP3 format!
So if you want to rip (record) some music from a CD into MP3, then put it on your vaio, you will have to rip using another media player, like Windows Media Player, or iTunes!
Hope tis helps
I didn't say i wanted to convert to mp3. The point is I have a large collection of mp3's I don't want converted into anything other than mp3. Sonicstage is being rather stubborn about it. Any ideas on how to save the mp3s to the Vaio using sonicstage? ( considering the second screenshot i posted earlier )
well if you have SonicStage 2.3 you should just be able to Import the MP3 files from a folder on your computer and then transfer them straight to your vaio (this is how it works for me)
