Hi guys,
The Sony site is sending me on a loop...
Pick country / pick model / see download section / pick country.......... etc
The trackpad scroll facility has stopped after reinstalling Vista due to a broken hard drive.
The control panel shows a 'mouse' and clicking into it gives options for a mouse, not a trackpad.
I think I need to download the driver for the trackpad so as I can use the scroll feature on the right vertical edge of the pad.
Does anyone know ehere I could find this please?
VV
Hi VoxyVaio,
Try this link:
http://www.sony.co.uk/support/en/product/VGN-N21E_W/updates
You will find the touchpad driver in preinstalled drivers and utilities > Windows Vista > Original Drivers Package – Pointing folder.
Rich
Hi VoxyVaio,
Try this link:
Rich
Hey!
Thanks for the reply Rich - I'll get on it!
VV
