Hi all!
Is it possible to upgrade the processor on a tr5-mp? If so, what should I be looking for to purchase?
Also, I'm looking at getting a bigger hard drive for it. I assume it's a standard 2.5" drive, but is i easy to get to?
Thanks in advance,
Mike
I believe the hard drive is a 1.8 inch ATA 50 pin jobby. I wouldn't even think about changing the processor, the TR5MP is an ULV Pentium M so any upgrade currently available would be pretty insignificant.
This forum is dedicated to users of the TR5MP so you may be able to get more specific help there.
thanks Rob. I'll check out that forum!
