My TR2 won't boot up.
It claims that a file called 'ntoskrnl.exe' is missing, but won't go to DOS to allow my search for it, just hangs.
Do I have too re-install the Recover disks and will I lose my pst file if I do.
Can I install this file another way?
Thanks
Insert your Xp disk into the CD drive, choose the boot from command prompt option in the menu that you are presented with
At the command prompt, type in the following:
copy d:\I386\Driver.cab c:\system32\ntoskrnl.exe /v
where d is the letter of your cd drive
press enter
Take the CD out when verified and reboot your computer
