Hi, I wonder if anyone could provide me for a link for the touchscreen driver for my all in one VPCJ23M1E? I had to do a system refresh in Windows 8 and now the touchscreen will not work.
Thanks
Thanks for the link but it did not work. In the end I had to use Item 17 on the link http://www.sony.com.sg/support/download/459105#downloadScrollable
This got the problem sorted.
Hi gbleach,
There doesn't seem to be a dedicated Windows 8 driver for the touchscreen. Have you tried the original Windows 7 driver?
http://www.sony.co.uk/support/en/product/VPCJ23M1E_B/downloads/UNDOTH_00248191_0042_5818
Rich
