The touchpad on my VAIO is way too sensitive. It's constantly copying text; it's scrolling through web pages at ridiculous speeds; it moves files all over the place; and it clicks into files etc by itself. It's driving me crazy. I only have it one month and already I feel like throwing it out the window. Any advice would be appreciated.
Hi AntoW1,
Can you first check that the correct driver is installed? Open Device Manager and expand ‘Mice and other pointing devices’ – you should have a Pointing Device listed but if there is a PS/2 mouse then the correct driver is not installed.
Otherwise have you checked the mouse properties and options either via Control Panel or Vaio Contol Center? If you have a Synaptics touch pad you will find the sensitivity and scrolling adjustment by opening Mouse Properties, clicking the Device Settings tab and then ‘Settings’.
Rich
