I ve recently installed Windows 7 ultimate and am having trouble finding touchpad drivers for my vgn-fw31m, i was assuered that the vista drivers would work fine my microsoft staff but i havent found them.
The touchpad works sort of but i cant scroll with the side of it.
Its a genuie copy of windows too.
Any help much appericated.
Hi hannon565 and welcome to Club Vaio.
Have you tried installing the Pointing Device Driver from here?
http://support.vaio.sony.eu/computing/vaio/downloads/preinstalled/index.aspx?l=en_GB&m=VGN-FW31M
You may have to wait for a dedicated Windows 7 driver if this one does not work.
Hey thanks, I think i have.Thought i might've had to wait till after the 22nd just thought would ask
I have the same problem, why aren't there any drivers yet?
And on that theme: why isn't multi-touch supported?
..the same problem..if you have,please send me download link of this driver/utility for touchpad driver win7 64bit. thank everyone
There is a FW Windows 7 64-bit Alps Pointing Device Driver on the FW56Z page here:
http://support.vaio.sony.eu/computing/vaio/downloads/preinstalled/index.aspx?l=en_GB&m=VGN-FW56Z
There is a FW Windows 7 32-bit Alps Pointing Device driver on the Z series page here: -
http://support.vaio.sony.eu/computing/vaio/downloads/preinstalled/index.aspx?l=en_GB&m=VGN-Z3
I can find a Windows 7 32/64-bit Synaptics Touchpad Driver for the AW series etc. here: -
http://support.vaio.sony.eu/computing/vaio/downloads/preinstalled/index.aspx?l=en_GB&m=VGN-AW41JF_H
.......... at your own risk of course!!!!!
And make sure you use the right driver (Alps or Synaptics)
Hello.
I have the same problem, but I can't know which driver I need: Alps or Synaptic. I tried looking at the Device Manager, but it recognises my touchpad as a PS/2 Mouse, so I dont know which type of driver it has. Which one should I install?
PD: I have a Sony Vaio VGN-FW4 (bought from Sony Style).
Hi Tinrik and welcome.
The FW-Series Vaios all use the ALPS Driver.
please give me sony touch pad drivers....
please send me touchpad drivers for Sony Vaio sve15..
