Can anyone help me rectify a problem I have - my laptop touch pad left click is not working. Right click is fine and attaching a wired mouse it works ok but I would prefer to use the touch pad...Thanks ?
Hi suec2100.
In the majority of cases, this is caused by a hardware fault and may need a repair.
You can try reinstalling the Touchpad driver - I can give you a link if you tell us which Vaio Model you own - to check for a software issue.
Is your Vaio still within warranty?
Sadly my laptop is just out of warranty......not sure if you require the VPCEE3EOE number? I think it is just the basic windows 7 home model....Thanks.
There is an update for the ALPS Driver on the download pages for your model here: -
http://www.sony.co.uk/support/en/product/VPCEE3E0E_WI/updates
It is not designed to address this particular problem but it may be worth a try.
I have tried this option but it said I already have the latest download so sadly it hasn't really helped. Thanks for the suggestion though..
