All the PCG-GRT815E has an internal mini PCI slot available which is not documented.
Does someone know if may I install a wireless mini PCI card? The PCG-GRT releases in USA has built-in the wireless but the European versions has the slot empty.
I would double check before installing anything.
Hi.
I own a Vaio PCG-GRT785E (european version).
This model does also have such an empty minipci slot.
I tried to install an Intel Wireless Pro 2200BG MiniPci card.
This card was then detected and installed but I am unable to establish a connection.
The System says that the card is turned off by the hardware based WLAN switch.
Unfortunately my model does not have such a switch.
I don't know what to do in this case and I am still waiting for a reply from Sony.
Do you have any ideas?
Before installing a WLAN card on your machine you should better check if it is equipped with such a switch!
Best Regards,
Tim...
I am only guessing but there might be an internal and no doubt undocumented jumper or post where the switch would connect.
Have you tried installing software to control "on & off", maybe you could install the original software from the USA Vaio site for the relevant american model.
Try Vaio Village and follow the links to USA workshop manuals.
http://p200.ezboard.com/bunofficialsony
William
It's an independant site ran by Ghost.
Its a good source of info, they seem to do more internal fiddling, and the link to the USA Vaio site is useful, they seem to have a lot more updates than Europe.
BUT please make sure you have the right model (USA model) and use at your own risk.
William
Yeah it's a good portal
After posting I went to check on available updates for the TR5MP on the Sony USA site & there were loads. Even though they were for the TR5AP (USA equivelant) they checked for the Vaio model they all installed.
Lucky USA Vaio owners.
Remember please, I used these updates at my own risk and so does anyone else.
William
Yeah sometimes the US updates are very handy.
BTW congrats on 1000 posts William
