Hey, Just reformated my Sony Vaio VPCF22L1E and I have installed all the drivers from the sony side, but still the FN shortkey wont work. Well... the mute and volume + and - are working but not the rest like the screen brightness and so on.
Any ideas of what I shall download or to get it work?
(Yes I totaly reformated the laptop so none of the pre-installations are left, because I wanted a clean format)
Wich I think sony has made a bad descission about this that there isnt any kind of complete installation of drivers and utillities to download after a reformat. And that you're not allowed to get the vaio uppdater what so ever after an reformat
Thanks in advance, your Maskukert
Hi Muskukert,
Have you downloaded and installed 'Sony Shared Library' and 'Sony Notebook Utilities' - In that order?
Rich
That solved the problem, thanks alot Rich once again
You're welcome Maskukert:smileyhappy:
