How can I check continuesly the temperatures of my vaio desktop and till what temperature is it crtitic or normal after running it a day maybe two days???????? Want somethimes after hard working the cpu temp is around 47 degr celcius, is that ok?????? please give your advice guys!!!!
same temperature here, but I have a labtop(northwood CPU)
get this
it shows the ACPI and the harddisc temperature.
if you have a northwood too:
72 degrees are critical and over 90 degrees= good by CPU
47 degrees is perfectly fine.
