Hi folks, Can anyone tell me when I try and delete Temp folder, there is a folder or two, that wont delete, Message comes back saying its being used by another program! or computer!!
I tried searching for it, cant find out what it is, its 0mb! just annoying as I have to delete the contents separately, cant delete all at once. Any help please, hope I have explained myself properly!! :smileygrin:
Hi carlowlass,
Which Temp folder are you talking about?
C:\Temp
C:\Windows\Temp
C:\ Documents and Settings\Your User\Local Settings\Temp
And what is the name of the folder that will not delete?
if your on about the temp folder in the Appdata folder some folders and files you will not be able to delete as there used by the system and cannot be deleted
