Is there a Vaio expert out there who can tell me, in laymans terms, the correct connections and procedure for playing back pre-recorded T.V. programmes, DVD's etc., through a T.V., rather than the integral screen ?
You need to connect from the TV out, which is a yellow plug to the SCART IN. You need one of those converters which converts phono to SCART. Then you can connect the audio via line out / headphones 3.5mm jack to phono pair.
