Anyone got them?
I had backed them up but in a format, forgot to reback them up
If anyone could grab the main Sony wallpaper from the Windows directory for me please?
I only need the one set to the resolution of the screen (1280x800 at the highest quality)
I'm after the more subtle one, i know they had another one of an animal or water or something? Just the whitish one will do
Thanks
Hi Akash84,
What was the name of the wallpaper, or can you describe it for me..?
Hiya,
It will only show if you have the original install on the SZ laptop
I wish I knew what it was called but I suspect, its Sony something
If you right click on your desktop>properties>desktop tab... you may have it there in the list of files (thats if you have not deleted it and are using the sony install).
Describe... well, its more white/bluish than anything. Said sony in the middle with a few wavy lines from what I remember.
It does not help with me looking at the Bliss XP Picture because its confusing me.
does that help at all?
Thats brilliant, thank you for that!
It was the first one I was after
I'm suprised I kept anything Sony related installed but the wallpaper is quite subtle and brings out what the screen is made for!
Thanks again!
You're welcome, glad I could help..
