Hello all.
I just bought a SZ2XP. After only a couple of hours running I had a big problem:
The display wont work on the NVIdia chipset. Enevn the Vaio logo won't be displayed properly (I have black or white lines from top to bottom), I hardly even recognize the Vaio logo.
If I run it with the Intel chipset, everything is fine.
I changed drivers (tryed many).. nothing helped.
I suspect the memory of the NVidia chip to be damaged (not the first time with NVidia boards..)
Any idea before I send it back to Sony?
Thx for help
Take it back to the retailer you bought it from and explain it's not working
Hi Kee-Lo mutli posting....:smileytongue:
