Can someone send me detailed instructions to replace a damaged key on the SZ series? Please email to mike(at)golfhi.fsnet.co.uk
thanks
Mike,
If you e-mail Tony Beard (one of the Club Vaio Experts) he will send you a copy of the official Sony instructions.
You will find his e-mail address in his profile - TonyBeard.
I think it is aklbeard AT netscape DOT net
Received instructions today from Tony. Thanks for the lead.
I noticed that the instructions are headed by a list of models A,FS,K,FR & NV which does not include the SZ range- can I assume that the fitment is the same? If not any idea where I can get the right instructions?
regards
Hi mikezoe,
Do the fittings on your SZ look the same as the ones in the guide that Tony set you..
If not you could try contacting Vaio-Link and request the correct instructions for your SZ from them..
