I deleted the recovery partition and I did not create any recovery discs. Now my system doesn't work properl. How I can get the recovery discs or where I can find it to preinstall my system.
Thanks.
Pawel
Hi siemien and welcome to Club Vaio.
If you did not make any Recovery Discs before formatting your hard drive, you will need to order a new set from SONY VAIO-LINK - probably about £60.
