Hi!
I have my Vaio FS215S for almost 2 years, and it is now taking a long time to startup, and with slow browsing and processing. I am thinking to do a system recovery, so my notebook will be faster and cleaned. Shall I do it or shall I just look for a registry cleaner?
All sugestions are wellcome.
Thanks
Luís Martins
Hi Luís Martins,
The choice is yours but I usually do a fresh install at least once a year..
if you decide to recover your Vaio here is a guide on the process..
Hi Thalamus!
Thanks for your opinion, and for the link.
Regards
Luís Martins
You're welcome Luís Martins..
If you're going to do a recovery don't forget to back up important data first..
