I went to check my msconfig today and I noticed my "Startup Selection" was set to "Selective Startup". I certainly do not recall doing this and have been having no problems with my computer so I was wondering if it's meant to be like this? Should I leave it alone or change it back to normal startup?
Thanks!
Hi bingefeller,
This is normal if there are any items on the ‘Startup tab’ that have been disabled from running at startup.
Rich
Thanks Rich. I'll just leave it in that case.
You’re welcome bingefeller
