Hello, I've owned a Vaio SVF15A1M2ES model for about 2 months now and I seem to have a annoying issue with the fans. The laptop is generally silent but every 2 minutes or so the fans with speed up and be noisy for a while then go back to silent and rinse and repeat. I use speedfan to check the temps and they don't change at all, even if it is getting a little hot it shouldn't be going so loud. Looking at task manager and everything will be on 0% usage except for memory which is around 20%. I am on Windoes 8.1 if that helps.
Any help would be appreciated.
