after starting up my viao nr11s/s the curser sticks for about 1 or 2 seconds fees and then is ok.
very annoying any body had this problem if so can i fix it.
mike
Hi Mike,
when exactly does the cursor on your NR11S stick.?
What's listed under Mice and other pointing devices in Device manager.?
To open device manager press the windows key+R to open the Run box then type devmgmt.msc and press OK
Click Continue on the User Account Control window.
could not see anything unusuale , happens just after start up.
thanks for reply.
mike
