Hi, hoping someone can help, please?
Had an FS415B since February of last year and everything's been fine, but over the last week or so a strange problem has begun occurring with the sound - it's similar to the sound you get when a vinyl record is sticking, but at a very high speed - something not unlike the effect they used in Max Headroom (for those that can remember).
I noticed it on some MP3's I'd downloaded, then on some live streamed music and now it's even occurring on the start up chimes - a kind of sticking distortion.
Can anyone help, the guarantee runs out very soon and I need to get it looked at if it's not something I can sort myself?
Thanks in advance.
Hi Boris71,
Welcome to Club Vaio,
If your warranty runs out in February then i would register a case with Vaio-Link as soon as possible..
Hi Boris71 and welcome to the forum.
Just a thought, but have you defragment your hard drive recently? It may or may not help but worth a try...
Thanks for the welcome guys.
Thalamus, just registered a case, cheers.
Rich, wouldn't have a clue how to defragment my hard drive - I'm a complete ignoramus on these things (some would say many others as well) - is it difficult to do?
Hi Boris,
To defragment your hard drive..
Goto Start > All Programs > Accessories > System Tools > Disk Defragmenter..
A new window should appear, highlight the C drive and click defragment, once this has completed, do the same with the D drive.. (if you wish you can press Analyse, this will inform you if windows thinks the drive need to be defragmented or not.)
Thanks Thalamus, I'll give this a go.
Fingers crossed it sorts the probelm.
Let us know if it helps..
Morning,
Defragmented over night - but at work now and didn't have a chance to check before I left this morning - will check it out when I get back tonight.
Something else I stumbled across on this forum though, was a thread started by Masood KH on September 28th - where Blencogo and Resonate help radie and DDF solve an issue that sounds very much like mine:
http://www.club-vaio.com/clubvaio/mvnforum/viewthread?thread=36031&offset=30
DDF solved it by
: i just desintalled the drivers of the Primary IDE, and rebooted. No hotfix no nothing
Is this a simple operation - I've googled, but can't find any instructions.
Excellent, thanks Rich.
