recently, i looked into msconfig and there seems to be a blank entry
look at this screenshot. can someone pls tell me what it is, can remove it??
look at the entry right above "VOR"
Since you already have it unchecked, if everything is working okay then feel free to delete it.
I don't think it does anything anyway, since there is no command.
If you're brave enough, look in the registry with the registry editor. The key is in the "location" column. Perhaps there is more information in the registry.
i have tried deleting it in "regedit" but it says something like this
will it affect my system if i just leave it???
It should be okay to just leave it if you are not experiencing any problems.
You can download "Ad-Aware" if you want to scan the registry for unwanted entries. I can't remember the link, just use your favorite Web search engine.
ok, thanks for the replies
cheers :smileygrin:
