I have bought a jack plug to phono lead and my VAIO pocket gives very patchy output - any ideas?
Sounds probably either :
1. Dodgy cable
2. Loose connection in the docking station
I have used mine with a cable into my monitor no problems....
Matt
Hello,
usually the phono line-in is extremely sensitive so that the signal will be very distorted. Use a normal line-in (AUX, Tuner etc.) and the sound should get better!
Ciao,
Carsten
Hello,
Ciao,
Carsten
