I haven't installed any programs yet, so I would like to know which of these programs I can delete from this list (msconfig) without my vaio crashing or so:
Ive disabled VAIOupdt and switcher. The vaio update you can access from the start menu amd switcher via program files directory should you want to control bluetooth and wireless seperately.
Im not sure if the other programs can be disabled so if they can then somebody let us knw
cheers
This depends on what you need at StartUp
DO NOT DELETE
NvCpl RunDLL32.EXE (System file)
Apoint.exe (Your touch pad)
ISBmgr,
ICO.EXE (depending on if you use a mouse)
These are up to you
Wireless Switch
VCUServe (Your digicam or web cam)
SPmgr (Power management i have deleted mine & its perfectly fine)
VAIOUpdt (Depending if you want auto updates to VAIO)
BlueTooth Manager (Depending if you use it as you can manual start up)
Im not sure on ehome
However turning these off will not dramatically improve system startup you maybe better leaving them unless you do not use them
