Recently when i start up my laptop it does not appear to load all the programs every time. Sometime the wireless connection software and bluetooth loads other times it doesnt appear in the task bar.
Why is this and how can i fix it please?
Firstly i would check if the applications are properly loading there is a good stat up manager located on Microsoft Technet sysinternals web site, The application is called auto runs
Microsoft / Sysinternals
If that dosent solve the problem try downloading the Process explorer its an awsome replacement for windows task manager
This program, StartUpList is supposed to be better than MSConfig
thanks you 2, it works now
