Hi Guys, i have the following start up processes on my computer, do these slow my laptop down drastically? Which ones should i take off? Please take the time to read this. IF you want to email me then email me at: hbriggsreeve at yahoo . co . uk if any malicious emails are recieved then i will take action!
28 Processes in total start up!!
Located: HK_LM:Run, AcctMgr
Located: HK_LM:Run, ATIModeChange
Located: HK_LM:Run, AtiPTA
Located: HK_LM:Run, ccApp
Located: HK_LM:Run, Drag'n Drop CD+DVD
Located: HK_LM:Run, ezShieldProtector for Px
Located: HK_LM:Run, HKSERV.EXE
Located: HK_LM:Run, Lexmark X1100 Series
Located: HK_LM:Run, Mouse Suite 98 Daemon
Located: HK_LM:Run, POINTER
Located: HK_LM:Run, QD FastAndSafe
Located: HK_LM:Run, SynTPEnh
Located: HK_LM:Run, SynTPLpr
Located: HK_LM:Run, URLLSTCK.exe
Located: HK_LM:Run, BearShare (DISABLED)
Located: HK_CU:Run, ctfmon.exe
Located: HK_CU:Run, Memory Optimizer
Located: HK_CU:Run, PicoZip
Located: HK_CU:Run, SpybotSD TeaTimer
Located: HK_CU:Run, Symantec NetDriver Monitor
Located: HK_CU:Run, Mozilla Quick Launch (DISABLED)
Located: HK_CU:Run, PicoZip (DISABLED)
Located: Startup (common), Adobe Gamma Loader.lnk
Located: Startup (common), Microsoft Office.lnk
Located: Startup (common), PowerPanel.lnk
Located: Startup (user), Norton System Doctor.lnk
Located: Startup (user), Samurize.lnk
Located: Startup (user), Screen Saver Control.lnk[:">] [:">]
That seems like a normal startup Harry.
PS: don't worry, spam bots won't be quick to pickup your address as it's not a hyperlink, but if you did something like harrybriggsreeve AT tiscali DOT co DOT uk then you'd be safe
Merci Kee-Lo
