Hi, a friend of mines has a Vaio AR series laptop. He is having an issue with it however just now when trying to boot up the pc. He keeps getting the attached error message. Does this mean his HD is corrupted in some way?
Hi leethepee,
has your friend followed the steps described on the BS.?
Hi leethepee,
Apologies, what does BS mean?
When he showed me the laptop, I tried to boot in safe mode but ended up getting the blue screen again. I'll have a little read of the link you have sent me, thanks for looking into this. 🐵
Good luck..
after looking it does appear to be quite a bad prob. I have seen there is a way to boot from a floppy drive but neither of us have one. Do you think it could be booted from a USB pen instead. If I can boot from disc I can force the PC to do a chkdsc operation and possibly sort the issue. Its either that, or the HD is completely goosed. With an HD issue such as this, I guess there is no way to reformat the HD and just re-install XP Pro?
