Ive just installed the new SS 3.3 and its saying that to use my player with it i have to delete all the ATRAC tracks off it or initialize the hard drive of it. i dont wanna do this as theres 2287 tracks on it and i simply cant b arsed puttin that lot back on it. help plz
thanx
Dan
As in so many previous posts, have you ensured that the SS3 software is for your part of the world? I am in the UK and I had the same problem as I was using the US version, I downloaded from the Connect UK site and all went smoothly, no deletions ot initialisations etc.
