Two days ago I got my brandnew wonderful SRX51P/B. Now I have problems with the Touchpad. It dosn`t work under XP Prof. and I recorevered the system several times in all the different possible ways. During recovering the software the Touchpad buttons are working properly, but when the installation switches into the XP installation only the pad works but not the buttons. Later in XP the same situation. I deleted the ALPS Software, reinstalled everything but without any positive effect. Before I ask Sony for repairing, has anybody an idea why this happens?
Thx a lot from Germany
Ulrich
Go to the ALPS website and get their latest drivers.
If you means www.alps.com there is no support / downloads.
I am using this one:
http://www.csd.toshiba.com/cgi-bin/tais/su/su_sc_dtlViewDL.jsp?soid=811154&moid=null&ct=
It seems strange that the touchpad works initially which suggests it is not a hardware problem.
William
