how can i remove spotify from menu start?when i start comp spotify starts automaticaly, how can i change this?
Hi picassor,
You don’t say which operating system you are running but the usual procedure would be to open System Configuration, click on the Startup tab, uncheck the Spotify program and then click Apply.
To open system configuration in either Vista or Win 7 click Start and then type msconfig in the search field – then click on the result (msconfig.exe).
Rich
