help split coke on my laptop, keys are sticking some not working, have tried to take it apart But cant find all the screws, i am having to cut and paste some of the letters as two are not working at all(more i exspect soon) please help cant afford to take it for repairs:smileysad:
sad and depressed
curls
Hi curls and welcome to the forum.
If you need a disassembly guide it would help if we knew the model number.
Hi curls and welcome to the forum.hi and thanks
hi and thanks its a PCG-K115M
curls:smileyhappy:
Sorry, unfortunately I have never managed to find any disassembly instructions for the K series. You could always try a Google – you may have more luck that me.
With a bit of luck another member may be able to provide a link.
You could try snorting it out from between the keys.
Nasty, a friend did a similar thing to his Toshiba... left it a few days and it was OK, thank goodness.
We got a cleaner for the keys from Maplin, worked well
