Please Help:smileycry:
A work mate spilt a bit of his coffee over my fantastic S1XP. Fortunately, most of the coffee was spit onto the casing (over the Windows, Intel and ATI logo) which was eaisly mopped up. However a little bit of coffee went down the cursor keys at the bottom right corner. I thought that everything was fine. Turning the keyboard over and taking the little coffee that could be removed and all was working. I few hours later however the cursor keys are still working but they just feel stiff when pressed.
Can anyone give me some advice on how to clean the underside of the keyboard or should I just leave it as everything still works.
Thanks for your help
Adam
Clean it now Really Adam
This Maplins link may be of use .
Better to clean it now than let it get other stuff sticking to the tiny bits coffe that may still be left .
This one covers most cleaning needs
Hope the link is of use .
Thanks for your help.
