Hey All...
Im off to Uni In September and got a new Laptop Sony Vaio PCG-K195BP and speakers are good on it but i just want some little extra sound so can sum1 please reccomend me some external speakers....
Many thanks
Sam
hi,
fujitsu-siemens has a mini sound system with subwoofer... its small, the sound is ok, and the base soft. cost in europe aboute 19 ¿.
joe
JBL creatures are very good and look cool around £69 or Harmon Kardon sound stick are cery cool and LOUD around £120 :smileygrin:
Harmon Kardon are very nice speakers.
I recently bought a pair of Sony powered speakers and they sound fine. They were about £30(UK).
I've got them plugged into a Freeview Digital TV box at the moment (for the radio) and they sound fine.
The model number is SRS-A205
There's others that I think are better than the typical PC "multimedia spkrs" - depends on how much moolah you've got. Edirol and M-Audio have some nice reference standard speakers in the £100-200 range. Also you could probably improve things by using a USB sound "card" like the M-Audio Transit or similar from Edirol - either in the £60-£100 range.
