I have a VGC-V2 desktop & want to connect audio speakers. I've been told I can connect 2.1 speakers without any aditional equipment? What should I buy without spending a fortune & how do I connect. Is it possible to use wireless speakers?
I think you can use the headphone socket to connect 2.1 speakers
Wireless ones are a possibility, but they're probably not cheap
Well if you were to go with Sony Wireless RF Headphones, they are indeed not cheap.
These Headphones on Ebay were £79.99 but they are advertised for £39.99 at the moment.
If you are fan of eBay, you may want to have a look at the auction.
EDIT: Oh sorry you said SPEAKERS, lol not headphones. Sorry having a dense tired moment there. :smileyd_oh: D'oh!
Maybe wireless headphones might be a possibility?:smileyblush:
LOL James
Hasn't the VGC an Line-out?
If yes, use your HIFI:smileycool: or active-speakers.
Don't think so
This device definately has a line-out port on the right side on the back.
So it's no prob to use active speakers or even your HiFi as suggested before.
njoy, asseeger
im not hundred percent sure on this but i have the vgc v3s system and i was told to run out of the optical out connector and then run it to normal speakers from the control box that u can get with a speaker set up ..... bit vague but may point u in the right direction if i get somewhere i will let u know
