Hi all
I just bought a sony vaio vgn-n11m notebook. Thought it was really the dogs bollix until i started to play music on it. The speakers are dismal!! Anyone have a suggestion other than buying external ones?
How could there be any solution other than external speakers? Most, if not all, laptop speakers are poor. Some are poorer than others though. Most have zero bass but when the treble is tinny it accentuates this. If you have tinny speakers nothing can be done I'm afraid, it's external speakers time.
I had the same problem with my AR21S and overall I find it brilliant, I use mine as a desktop and wasn't overly impressed with the speakers, purchased Audica speakers, not only look good but have a great sound too. www.audica.co.uk
