Can any one help I am getting a Hall/echo on my speakers which are connected to my RA304 any ideas?:smileyconfused:
Hi
This is due to the settings in the RealTek control panel in the system tray
Sorry, but I cannot find RealTek?
Try a double click on the system tray 'speaker' icon and see whether this takes you to the RealTec Control panel.
Found RealTek, tried some configurations still the same echo?
Found the problem the, the reason was in Sound Effect Manager in controll panel, problem now sorted thanks for your help!
