Hello, I had problem with my computer, so I had recovered it and was in the stage how I did opened it for first time. Then I was updating Vaio update and one of it was IDT Audio, than after my computer didn´t have sound, but there is sound when I use skype. I don´t know what the problem is, try to delate IDT Audio, but didn´t help. Could you help me pls? Thank you very much.
Hi denkanova,
To determine whether you have the correct audio driver installed we need to know the model number of your Vaio.
Also have you checked in Control Panel > Sound > Playback that Speakers/HP is selected as the default device?
Rich
