For some reason each time I adjust volume or try sound it says:
"There are no active mixer devices available. You may install or activate mixer devices from Control Panel. This application will now exit."
No it's not that it has been disabled. Apparently it thinks I don't have a sound card installed but I do. I don't know what has happened.
Where can I download the sound drivers for the VGC-V2M (specific link please).
Thanks.
By the way, there's no chance of changing usernames is there? I don't even remember registering as this. It was over 2 years ago and I had to recover the password.
Hi A-lastair-M,
Welcome to Club vaio,
You can download the Pre-installed drivers for you V2M from here ...
Hi A-lastair-M,
Welcome to Club vaio,![]()
The install file does not work in the audio folder. Nothing happens.
Hi A-lastair-M,
Do you still have Audio drivers in C:\Drivers\Audio, if so have you tried using those..
Hi A-lastair-M,
Glad your sound is now working..
