Hi
Sorry for my english.
I have been reinstal windows xp on my VAIO, and now I cant install my soundcard. I use drivers from my disk C. But nothing.
System tell me about Microsoft Bus driver. But it installed in my system.
Please, Help Me!!!
Alex
Have you checked if there's an update on vaio-link.com?
Yes
Hi.
I had the same problem. The audio driver in the package on the vaio support site seems not to be the correct one. I used this driver directly from realtek.com: HD Audio CODECs from realtek. After installing these drivers, you have to go to the hardware manager ("gerätemanager" in german, i don't know the correct english name). Under system devices ("Systemgeräte" in german) was a "PCI-Device" that was not correct installed. But when you let windows search the driver after having installed the HD Audio Codecs from Realtek, it should find the correct drivers itself.
That was the solution for my FS115M.
Regards,
Roland
Thank you, Roland very much!!!
I`ll try it.
YESSSSSSSS
It's working!!!
Thanks averybody, and you, Roland!
